Old 12-06-2007, 03:59 AM   #1
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
Default Car Wont Start
Hey I have a fuel issue. I was driving to the store and when I stopped at a light the car died and wont start back up. It cranks over and all but my AFPR shows 0 PSI. So I figured my fuel pump went out, I replaced it with a Walbro, wasn't that. So I swapped the fuel relay sensor on the passengers side of the engine compartment, wasnt that either. I have been trying to find an answer in the TSRM but I havent been able to find anything. HELP PLEASE! What could it be...
Thanks
teedoff00 is offline   Reply With Quote
Old 12-06-2007, 06:36 AM   #2
f00g00
Did you troubleshoot using this as a guide?
MK3 TSRM On-Line
specifically the first on the page, it has some more things to check then just the fuel relay sensor.
Did you check the EFI fuse for instance?
Old 12-06-2007, 06:42 AM   #3
teedoff00
teedoff00's Avatar
yeah I already switched out the fuel relay sensor, I basically dont have any registering fuel pressure, so I figure something isnt turing on the (new) brand new fuel pump (thought to be the problem). But what could it be... CPS, ECU, Sensor of some sort... What should I check and how is the best way.
Thanks again for all the help.
Old 12-06-2007, 10:03 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
have you checked the efi fuse? this will stop the injectors and fuel pump running
try jumping +B & Fp in the diagnostic box with ign on, do you hear fuel running?
Pics of my build.
Do a diagnostic first!
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
