Old 12-13-2007, 08:05 AM   #1
ma70guy
ma70guy is on a distinguished road
Default oil pressure switch
hey is there any way to check the oil pressure switch or gauge(i already looked through tsrm but i may have overlooked it) im not sure if its my gauge or the switch it will read pressure with the key turned some times but it starts to fall off and it acts like the gauge is sticking because i can tap it and its goes the rest of the down thanks for any help
ma70guy is offline   Reply With Quote
Old 12-13-2007, 02:05 PM   #2
abhattan
abhattan's Avatar
abhattan is on a distinguished road
I think if you use a multimeter you can test the switch. Whether in voltage or resistance, I'm not sure. But there should be something on that in the TSRM. They have to. As far as the gauge, I don't know, but it sounds like the gauge is faulty.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 12-13-2007, 03:29 PM   #3
CyFi6
unplug it and jump the lead to ground while someone inside looks at the gauge, it should go to max, then when you unhook it, it should go back to 0 iirc
Old 12-14-2007, 04:55 AM   #4
ma70guy
thanks ill try that im thinking it may be the gauge now that ive read some other peoples stuff
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Faulty Headlight Switch... please help! MusicNazi525 MKIII Supra 4 10-30-2005 12:31 AM
