#11 |
well I pulled my dip stick and it smells like gas and I bought the motor from a shop that imports motors from japan it only has 50,000 on it now and when I replaced my camcover gasket I never took the injectors out, I know you need to replace orings. I want to do a fuel pressure test on the fuel rail and the tool you need (sst 09268-45012) is not availible to buy, is there anyway I can take out the injectors and test them out of the car. I think the problem it getting worse b/c now it smelll more like gas when trying to start.
Supra Engine Powered Dragster |
#12 |
Just pulled the afm and all the resistances are within spec
#13 | |
![]() Quote:
But I can't see why that will cause your engine to play up. Possible options are fuel pump or filter, Throttle position sensor, computer is fried, spark plugs and leads, timing maybe out, blocked air filter. But as Suprra Girl said, "do a diagnosis!!!!". But I'm pretty sure your piston rings are stuffed. ![]()
1990 3.0Ltr GT Turbo @8psi Manual (Converted) |
#14 |
read the last line of my first post starting this thread
#15 |
Get a bigger budget or a smaller car man.
#16 |
sorry doing what I can im in college and paying for everything and my car is the onlything I have worth anything and it will be even more bad ass when I get out but for now I have to fix what I can and keep It on the road. I talked to the toyota intructor at my automotive tech school im going to and there taking it in there shop sometime next week so I hope it will be fixed. They should have all the tools to test it and give me some feedback.
#17 |
I did another diagnosis on the car and It gave me these 4: O2 sensor, TPS, Vehicle speed sensor, and A/C switch or neutral start saftey switch
87 Supra won't start | RNEMESiS42 | MKIII Supra | 3 | 06-25-2011 06:30 PM |
Car wont start hot | carfanatic89 | MKIII Supra | 41 | 03-30-2009 10:58 PM |
Supra wont start | Micahwc | MKIII Supra | 1 | 03-14-2008 05:57 AM |
Car Died...where to start? | Jrew | MKIII Supra | 4 | 10-26-2007 02:19 PM |
no start | 87supraguy | MKIII Supra | 5 | 03-23-2006 07:31 AM |
