Old 12-17-2007, 09:26 AM   #11
west_side_supra
west_side_supra's Avatar
all info is in the top left corner.
non turbo ignition
turbo ignition
if i am reading it right, you have got your black with orange, this is just a power wire for your ignition, then there is the black with white, that is the actual starter. so if i was to do it i would set it up like this
with a setup like this, this still requires use of your key. so operation would be
1.turn key to on position
2.press button or switch to start vehicle
and by doing this way it should help cut down on the amount of wiring required and labor :P best of luck
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 12-17-2007, 06:09 PM   #12
Supra2NR
Supra2NR's Avatar
so the black and white
and black and orange wires?
Old 12-17-2007, 07:10 PM   #13
Supra2NR
Supra2NR's Avatar
nvm i got it hooked up to the headlight washer switch and it works awesome
Old 12-17-2007, 07:25 PM   #14
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
ya i got mine hooked up to where you still need the key to have it work but good job dude i still cant beleive that the washer button actually worked lol
cyanide-is-a-way-out is offline   Reply With Quote
Old 12-17-2007, 08:24 PM   #15
Supra2NR
Supra2NR's Avatar
I kept the key start too,
Jus in case,
Cuz im a little bit worried since the washer wires were kinda skinny and could burn off,
But it works beautifully
What im trying to do now is make a little handle on top of my key so I can leave my key in the ignition and jus look like sumthing covering it
Old 12-17-2007, 08:47 PM   #16
west_side_supra
so my setup works?
yea i'd be worried about the difference in wire sizes
fidenza cam gears
Old 12-17-2007, 10:21 PM   #17
Supra2NR
Supra2NR's Avatar
Your setup works bro,
What I want to in addition is
Put a switch in between where I tapped the black and white wire and the igntion itself, so even if I leave the keys in the car they wouldn't be able to start it unless the
Headlight washer is used,
So this way, in case the washer switch screws up while im on the road I can flick a switch and I can start the car with no problem
Awesome supra vid!!!! check it 5upra lov3r Show n Tell 0 07-15-2008 07:53 PM
awesome mkIII video D_Train MKIII Supra 5 10-15-2007 05:55 AM
Fukn Awesome ozsupra Off Topic Forum 2 09-25-2004 03:42 PM
Im Feeling Awesome ozsupra Off Topic Forum 4 09-24-2004 02:20 AM
