Old 12-17-2007, 05:58 AM   #1
west_side_supra
west_side_supra's Avatar
Default um help?
how would i go about giving my car power to interior items, i currently have no motor in the car, i just need to get everything inside of the car to work for testing purposes.
any help would be nice, because from what i am understanding it goes, ground to body and block. then power goes to ignition, and starter. but i need to bypass the starter and nutural saftey switch. and i dont know where to locate my ignition wire, i guess that is my best way of putting it.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 12-17-2007, 07:00 AM   #2
Supra2NR
Supra2NR's Avatar
jus put power to the thick white wire on the driver-side front of the engine bay in the harness
that goes to the battery
and ground it to the body
Old 12-17-2007, 09:10 AM   #3
west_side_supra
ok well the white wire turned on my CEL, EVC, S-AFC and gave power to some gauges. thats cool that tells me 3 months have finally payed off, now i just need to know if the motor works lol.
now there is a brown wire near that white wire on the harness, that gives me power to some accesorys like cd player dome lights ect, but when the white wire and the brown wire both have power then just the acc items are working, and not the evc or safc
fidenza cam gears
Old 01-12-2008, 01:36 AM   #4
west_side_supra
ok now i have another problem, i have ran my fuel pump power onto the ignition wire when i should have put it onto the stock relay, and well i had it running for bout 2-5mins and then it turned off and so did everything else, the only thing that is on during the ignition position is my CEL, that at least is telling me that there is still getting power, but something wrong with my ignition power source, the fuse is fine so what do you think is wrong? i didnt see or smell any smoke so i dont think anything burned up
fidenza cam gears
Old 01-20-2008, 09:30 PM   #5
west_side_supra
can someone point me out to this white wire or brown wire on the TSRM, cause i cant find it. this problem is going to stop me from my build and i need to fix it asap. any help would be nice.
fidenza cam gears
Old 01-22-2008, 01:09 AM   #6
west_side_supra
supra2NR??? please, i got like a week now to get this figured out.
fidenza cam gears
