Old 12-18-2007, 04:42 AM   #1
XxSupra4LifexX
XxSupra4LifexX's Avatar
XxSupra4LifexX is on a distinguished road
Default Car doesnt like to idle in the morning
When i first start my car up in the morning after its been sitting all night the car doesnt like to idle. it will idle about 100rpm and sometimes it will even die. When i step on the gas i can hear the intake suck in air but the car doesnt rev up, in fact the car drops in idle. but once i put my car into gear and drive its fine. and once the car is warmed up it will be fine until the next morning. any ideas on what could be the cause of my problem?
1986.5 MKIII(7MGE soon to be 7MGTE)
XxSupra4LifexX is offline   Reply With Quote
Old 12-18-2007, 08:22 AM   #2
west_side_supra
west_side_supra's Avatar
probably the cold start injector
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 12-18-2007, 08:28 AM   #3
XxSupra4LifexX
yeah thats what i was thinking i just wasn't 100% sure. are the cold start injectors the same from the turbo motor and the nonturbo motor?
Old 12-18-2007, 08:29 AM   #4
west_side_supra
hell if i know lol i doubt it but you never know
fidenza cam gears
Old 12-18-2007, 08:36 AM   #5
XxSupra4LifexX
yeah because i have a complete turbo motor sitting in my friends garage. im taking it apart and putting better internals in it and all arp studs and bolts. but if they are the same i was just going to take the one off my turbo motor and throw it in. thanks for the help.
Old 12-18-2007, 03:01 PM   #6
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
brake booster, brake booster, brake booster. i have the same problem the car will crank and it will flucuate in revs and when you try to press the gas it like to die then rev up like 4 seconds later. i thought my cold start injector, which it still might be but i lost my brakes the other day and when i lost my brake my engine went weird reving slow reving high flucuating, and the brake booster was making weird sounds so look at the cold start injector or the brake booster.
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
tsupra89 is offline   Reply With Quote
Old 12-18-2007, 03:51 PM   #7
Supra2NR
Supra2NR's Avatar
or it could also be a boost leak sumwhere
Old 12-18-2007, 10:10 PM   #8
XxSupra4LifexX
Actually, i replaced the brake booster like 2 months ago. i still have all of my brakes, and it only happens in the morning. once the car is warmed up it idles. so i know its not my brake booster, and as for the boost leak, my car isnt turbo.
Old 12-18-2007, 10:34 PM   #9
Supra2NR
Supra2NR's Avatar
a vacuum leak then lol
Old 12-18-2007, 10:37 PM   #10
XxSupra4LifexX
yeah, i also thought about that. but wouldnt that cause the idle to fluctuate all the time and not just in the morning?
Finally, Idle Set! scruffboy Non-Generation Specific Questions 6 01-16-2007 02:39 PM
1987 Toyota Supra Idle spycialost9999 Non-Generation Specific Questions 3 06-14-2006 06:33 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
