Old 01-13-2008, 02:08 AM   #11
SUPRASONIK
SUPRASONIK's Avatar
SUPRASONIK is on a distinguished road
Originally Posted by Irish_Mechanic View Post
On all the other cars i've owned and serviced at my shop, i've always checked the heater hoses. There will be one in and one out. If one is firm and the other isn't while the heat is commanded on, youve got a clogged heatercore.
thats the first and most times easiest check. After that, in my chevy's i always take the control panel off and check the wiring pigtails to see which ones have shorted out (usually just behind the switch). Thats chevy, but an easy check also.
After the easy checks, you'll want to check the valves which, on my mitsubishi's have been inline with the heater hoses. you may need an volt/ohm meter and the appropriate values for a functioning valve. it could also be a physical deficiency. you can take the valves out of the car and check them too.
Let me know how you make out!
Hi there,i have checked the heater core and the hoses and they are ok,and also the heater switch inside the car.I also put a new thermostat in as well,the next thing i was going to do was the inline valve on the heater hoses. thank you for your advice
SUPRASONIK is offline   Reply With Quote
Old 01-13-2008, 12:30 PM   #12
ddmcse
ddmcse's Avatar
Cool vsv switch not working = no heat
toyota Supra pictures heater issue
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 01-16-2008, 11:39 PM   #13
SUPRASONIK
SUPRASONIK's Avatar
Hi there, after checking the heater core,the heater switch, the hoses,change the thermostat,it was the inline valve stuck shut no vacum, every think working ok now thank you 4 your help.
Old 01-17-2008, 12:08 AM   #14
SUPRASONIK
SUPRASONIK's Avatar
Originally Posted by ddmcse View Post
Well after checking the hoses,the heater core,the heater swicth,change the thermostat, it was the valve stuck shut.I did what you said in the pictures and the valve opened,now the heater is working.thank you 4 your help.
Old 02-23-2008, 12:52 AM   #15
trevor510
trevor510's Avatar
trevor510 is on a distinguished road
Default i think i found the problem
well like a week after i first posted, the heat decided to start working again. but it would only work when i first started the car, if i started it then went and got gas or something the heat wouldnt work when i restarted it. as of 2 days ago im back to no heat. But, looking under the hood the other day i relized the heater control valve wasn't opening. so i manually pulled up on it and volla, heat. but... it wont stay open. when i let go it just closes back and its not easy to open. i messed with it for bout 1/2 hour but it wont stay open, and i have a blister on my finger. do i just need to replace that controle valve (crossed fingers) or is it something electronically telling it not to open. oh, and yea it does make that weird rushing water sound, and all this time i thought that sound was normal, lol. thanks in advance for your help guys.
trevor510 is offline   Reply With Quote
Old 02-23-2008, 01:10 AM   #16
trevor510
trevor510's Avatar
Default ?
i dont get the pictures, i already have a line running off the top of the heater control valve where is that supposed to go?
Old 02-23-2008, 04:14 PM   #17
trevor510
trevor510's Avatar
never mind i figured it out.
87 turbo, 5spd
blitz exaust, meagan downpipe, custom cat, high-flow elbow, msd plugs, stage 1 clutch, fidenza flywheel, Turbo XS bov, slotted & drilled rotors, heat shielded air intake and IC piping
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
IC pipes and heat wrap questions. redmaro MKIII Supra 0 09-26-2007 08:00 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
heat getting into car sd88supra MKIII Supra 7 11-03-2006 12:47 AM
