Old 12-21-2007, 06:53 PM   #1
trevor217
trevor217 is on a distinguished road
Question Trouble starting when engine is warm
I just found this forum last night and spent almost 5 hours reading all the great info here. Anyway, I have an 89 turbo mk3 that has an odd problem when starting the engine after the car's been warmed up. I've seen it documented on a couple threads here, but nobody had a conclusive answer.
Here goes: If I drive for a 1/2 hour or so, stop at a convenience store and shut off engine, when I come back a minute later and start it it idles around 500 rpm or so, fluctuates a bit, and sometimes(about 50% of the time) stalls out. If I put the car into gear and begin driving, the idle problem seems to disappear. It doesn't do this on cold starts--it only happens when the engine is warm. I saw all kinds of suggestions in the other threads, spark plugs/wires/distributor...there's a lot of suggestions, but it seemed that none of them worked for the people that were experiencing the same problem I am. Anyone know what causes this and are there any fixes for it?
Thanks!
Trevor
trevor217 is offline   Reply With Quote
Old 12-22-2007, 03:27 PM   #2
jc-supra-90
jc-supra-90 is on a distinguished road
I would look at replacing your coolant sensor, they are very inexpensive and will probably fix your problem
jc-supra-90 is offline   Reply With Quote
Old 12-22-2007, 07:23 PM   #3
trevor217
Thanks for the suggestion! I will give that a try and report back with results.
I was starting to get nervous that nobody was going to respond!
Happy holidays,
Trevor
Old 12-22-2007, 10:31 PM   #4
CyFi6
i have the same issue and i posted on the other board about it, they just reccomended that i change the wires and cap/rotor and they also said that it could be the fuel rail heatsoaking and essentially "spraying out vapors" instead of fuel for a minuet/
Old 12-23-2007, 12:27 AM   #5
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
ya i would say it is heatsok thats the main problem i feel
cyanide-is-a-way-out is offline   Reply With Quote
At Full Engine Warm Up Engine Ildes Down And Sometimes Dies!!! RspecMKiii MKIII Supra 13 11-05-2009 01:56 AM
engine rewiring trouble mizuboi MKIII Supra 0 01-09-2008 08:33 AM
Need help! Trouble after engine rebuild joebuffalo MKIII Supra 1 04-29-2007 09:54 PM
Trouble starting? 87supraturbo MKIII Supra 3 10-03-2005 01:38 AM
