#1 |
I just found this forum last night and spent almost 5 hours reading all the great info here. Anyway, I have an 89 turbo mk3 that has an odd problem when starting the engine after the car's been warmed up. I've seen it documented on a couple threads here, but nobody had a conclusive answer.
![]() Here goes: If I drive for a 1/2 hour or so, stop at a convenience store and shut off engine, when I come back a minute later and start it it idles around 500 rpm or so, fluctuates a bit, and sometimes(about 50% of the time) stalls out. If I put the car into gear and begin driving, the idle problem seems to disappear. It doesn't do this on cold starts--it only happens when the engine is warm. I saw all kinds of suggestions in the other threads, spark plugs/wires/distributor...there's a lot of suggestions, but it seemed that none of them worked for the people that were experiencing the same problem I am. Anyone know what causes this and are there any fixes for it? Thanks! Trevor |
At Full Engine Warm Up Engine Ildes Down And Sometimes Dies!!! | RspecMKiii | MKIII Supra | 13 | 11-05-2009 01:56 AM |
engine rewiring trouble | mizuboi | MKIII Supra | 0 | 01-09-2008 08:33 AM |
Need help! Trouble after engine rebuild | joebuffalo | MKIII Supra | 1 | 04-29-2007 09:54 PM |
engine noise car dies after starting | tex1116 | MKIII Supra | 7 | 11-18-2005 06:47 PM |
Trouble starting? | 87supraturbo | MKIII Supra | 3 | 10-03-2005 01:38 AM |
