any info on these parts
im going to the phillipines for a month
and we are pretty close to japan so parts are everywhere over there im thinking of getting a steering wheel probly from momo or sparco but i have no idea what kind of hub to look for or what will fit into our mk3s what size steering wheel is better? deep dish? i have no clue im also gonna get a 4-point harness, any brand that has the best safety? strongest? anything that i should know of when buying this? i might even get a 2jz motor with the six-speed trans if i have enuff money also , i need a new oil catch can, and one more thing my power steering reservoir cannot be mounted on the same spot anymore bcuz of my turbo anybody know if i can use the NA reservoir for my car? |
On the power steering reservoir, use one the same size or larger, mount it higher than the pump, and keep the supply line to the pump less than 18" long. At least that's what works for 4x4's, I would think the same rules apply.:)
The steering wheel mount is typical for Toyota, tapered splines and a 14mm nut. I think most after market steering wheels are universal. |
