#1 |
I recently bought a JDM 7m-gte and noticed that on the thermostat housing cover( after the thermostat), instead of a vacuum thermo switch for the evap, there is a looks like a temp sensor 1 wire type. Whats this sensor for? Do I just remove it and not worry about it. I think the only coolant temp sensors need is for the cold start and normal coolant them sensor.
TPS Sensor and Auto Trans | btwilson86 | MKIII Supra | 5 | 02-12-2008 07:31 PM |
550 injector & lexus air flow troubles o2 sensor? | night-rider | MKIII Supra | 1 | 09-03-2007 08:52 AM |
O2 sensor? | rnoswal | MKIII Supra | 5 | 08-02-2006 01:53 AM |
Knock sensor for an N/A. | rnoswal | MKIII Supra | 2 | 11-16-2005 05:12 PM |
Knock sensor..........ebay. | rnoswal | MKIII Supra | 0 | 11-06-2005 07:24 PM |
