Old 12-31-2007, 09:11 PM   #1
mkiiisupra
Question Knock Sensor
Looking into the guide on this process, gonna do it first day i have off
But i have a question, what exactly is the point of running a ground on both sides of the wire?? Is it ok if i just ground the side in the engine bay?
Also, i read somewhere about crimping the connections to the ecu adds extra resistance to the wire and can throw off the ECU's reading. Would soldering both ends help this any?
Soldering doesnt seem that difficult, but this will be my first time doing it, any tips?
1990 Toyota Supra Turbo A/T
Old 01-01-2008, 05:04 AM   #2
supramacist
supramacist's Avatar
Tips?
Find a shop because if you frag your ecu.
You're looking at about 1 grand.
Old 01-01-2008, 12:18 PM   #3
mkiiisupra
what do you mean frag? ....
Oh and there are no shops anywhere around me who are at least partially good at what they do. or know what a turbo is, or know how to work on a 1990 vehicle... this includes the dealerships in the area who couldnt even do a proper break job, had to take vehicle back to them 4 times... sigh thanks but i will take the chances doing it myself.
Any tips would be appreciated though
Old 01-01-2008, 01:23 PM   #4
mkiiisupra
How to Solder | DoItYourself.com
Soldering Tools
I found this guidence with some soldering tips and just wanted to get a few clarifications
So for soldering wire for the knock sensor i need to coat the soldering iron with a tin compound, with this i coat the outside of the wires then when i begin to solder the wire together i need to apply a rosin-core.
What kind of rosin-core should i use for this job?
Type //%Tin//% Lead//Melting Temp (°F)
50/50//50//50//425
60/40//60//40//371
63/37//63//37//361
Old 01-01-2008, 01:59 PM   #5
supramacist
Frag means to fluck up and fry.
If you don't know how to Do it why are you experimenting with your car???
Old 01-01-2008, 02:25 PM   #6
mkiiisupra
it's not an experiment, it is true i am a new mechanic and the only experience so far ive had is with my vehicle, but i always make sure i research and find the proper guidence before i do a project...
I don't just jump in, and all i am trying to do is ask for any tips/ or help you or someone else could provide, you talk about supramainia being a bunch of elitist snobs and they dont help new people, this is basically what you are doing to me.
Old 01-01-2008, 02:37 PM   #7
supramacist
That's not true man.
I'm trying to get you to realize that if you don't know how to saulder.
The ecu is not the place to learn. You over heat one connection and it's as bad as shucking a truth in your tranny.
If you're using ebay.
You aren't researching. And if you think I'm bad try supramania.
I'm just trying to keep you from a potentially costly and time sensitive problem.. Because if you can't trust any one local to fix.
Wait till you find out you have to ship it to kalamazoo my friend.
The 4 corners I have looked for a new ecu and their are no na ecu's left to be had in america dude.
You have not even a foggy idea of what you have gotten yourself into with this car. I hope you have deep pockets and don't anticipate it being a daily driver because you haven't even put your first 5k installment into it yet.
Your'e awfull bloody cheaky for some one that needs help to melt metal and stick 2 wires together.
Performance Parts Aftermarket and Racing
Old 01-01-2008, 02:45 PM   #8
mkiiisupra
Just asking for any tips anyone may have, not to catch the crap you throw.
I have never used ebay, never will its crap. I do reasearch by browsing these forums and others, there is alot of guidence out there on how to go about this, but have not found much on the soldering aspect.
I really only plan soldering the wire to the connector for the Knock sensor and just crimping the wires together near the ECU... Perhaps if you would explain what the risk is, and why that would be more helpful
Old 01-01-2008, 10:15 PM   #9
Bill UK
AEM EMS
Bill UK's Avatar
Knock sensor related may be of some use, happy new year.
http://www.supras.com/06/techcenter/display.php?QID=69
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
turbo? Knock sensor? running lean? west_side_supra MKIII Supra 19 02-01-2009 07:28 AM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
Bad Knock sensor TWRViper MKIII Supra 5 08-31-2005 09:24 PM
