Old 12-31-2007, 07:22 PM   #1
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
Default Fuel issues!!
So my car died on the way home a while back, and wont start, my aeromotive afpr gauge reads 0 psi for fuel. So I replaced the fuel pump and still no luck, the car cranks and cranks but no fuel is registrared in the fuel rail. I tried connecting the Fp to the B+ in the diagnostic box and nothing happened, when I connected the Fp to the battery the fuel pump relay resistor just buzzed. So I have no idea what to do next, I checked all the obvious fuses, the ign and egn in the kick panel, the ign and efi in the engine bay. None are blown. Any ideas please help!!
Thanks,
teedoff00
teedoff00 is offline   Reply With Quote
Old 01-01-2008, 05:09 AM   #2
supramacist
supramacist's Avatar
Put the front end on ramps and jack the rear up and go under and trace back all the metal fuel lines and check to make sure you have no kinks.
If you do replace them, dealer parts.
If you have your fuel pump wired backwards it may still buzz.
So check your wiring job. You can either start at the fp and go forward.
Or the fuel rail and start back.
If all else fails......, Pull the codes.
Which. It sounds like your there.
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
fuel injector issues doc1 Non-Generation Specific Questions 5 03-30-2007 04:08 PM
