-   -   coil pack grounds (http://www.toyota-supra.info/forums/mkiii-supra/10474-coil-pack-grounds.html)
gomezmk 01-01-2008 03:05 AM
coil pack grounds
I have noticed in a couple topics of people talking about the coil pack grounds. I did a 7mgte swap into a na chassis so I don't have picture in mind of how from the factory the coils packs are grounded. The only ground I see in wiring diagrams are of the three coils going to the ignitor. Is there a seperate ground of the body of the coils to the engine somewhere?
supramacist 01-01-2008 05:01 AM
You have a ground for your ac and your starter. Your alternator also. Up in that area of the well.
Find a solid clean place in the well and you'll be good to go.
