Old 01-02-2008, 08:34 PM   #1
mkiiisupra
Question Tps
I'm trying to calibrate my tps, what settings does the multimeter need to be on? i have 200, 200, 20k, 200k, 200m for the Ohm setting
1990 Toyota Supra Turbo A/T
Old 01-02-2008, 09:25 PM   #2
mkiiisupra
I think i got it....
opened throttle vta-e2 4.80
VC-E2 i got 6.85
those both w/in the paramaters they need to be but....
When i do idl-e2 at .5mm space i get .03 and at .9 space i get .05
Does this mean the TPS is busted? tried calibrating it a few times, same result
Old 01-03-2008, 05:24 AM   #3
Pretaco
Pretaco is on a distinguished road
.03 or .05 ohms is good when the throttle is closed, or less than .04mm,
make sure it goes to infinity when throttle is open.
check this:
MK3 TEWD On-Line
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-03-2008, 01:55 PM   #4
mkiiisupra
ahh ok, cool thanks, it goes to infinate before its fully opened but it is infinate resistance when its opened up all the way
Was worried i needed a new tps. i just hope under the vibrations of the engine it stays calibrated. I have only one screw holding it in place, the other one wasnt there when i took it off and the plastic around it was broken off ;(
