Old 01-03-2008, 04:25 PM   #1
781supraturbo
781supraturbo's Avatar
781supraturbo is on a distinguished road
Default wire harness question!!
hey this is prob. a really stupid question but this isnt for me its for my friend and im not sure of the answer either... but is the 7mgte wire harness for a manual. the same as a auto wire harnes thank you very much..
brian
781supraturbo is offline   Reply With Quote
Old 01-03-2008, 07:36 PM   #2
Pretaco
Pretaco is on a distinguished road
Nope, the harness for the auto has extra connectors, and is missing some other ones. I have a trashed manual one, and a decent auto one, but I don't think I can use the auto harness for the manual car without hacking them both up and splicing it back together, which seems like too much work. (removing auto wiring, adding reverse switch, etc...)
I know you can't use a manual harness on an auto car without major modification. (adding wiring and connnectors.)
I haven't looked at the ecu pinout to see if they are the same.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-03-2008, 09:07 PM   #3
781supraturbo
ok thanx alot
Question on wire for rewiring KS redmaro MKIII Supra 8 09-30-2007 04:11 AM
Ignition / Wire Harness Question kidsusukigsxr MKIII Supra 2 07-11-2007 12:57 PM
Engine Harness question kidsusukigsxr Non-Generation Specific Questions 0 01-31-2007 05:33 AM
