Old 01-06-2008, 10:37 AM   #1
WhiteTurboZ89
WhiteTurboZ89 is on a distinguished road
Default help me, 2 questions
hi, sometimes my 1989 7mgte will die if gas and shift too hard.
but this only happens like 20% of the time not always. still i dont know wat it is.
2nd question - i drive for half hour or so to my friends house. turned off engine and stayed there for only 5 mins. i start the engine and the idle goes around 500 rpm and it fluctuates a little bit and sometimes (50% of the time ) it will competely die out. but if i turn it on and give it little bit gas right away the engine will go back to normal. my 7mgte doesn't do this when its cold it only happen when engine is warm.
WhiteTurboZ89 is offline   Reply With Quote
Old 01-06-2008, 08:51 PM   #2
suprakid91
suprakid91's Avatar
suprakid91 is on a distinguished road
2nd question happens to me too. i think its a bad vacume line somewhere. but thats probably wrong. i dont know.
91' 7m-gte, sold
suprakid91 is offline   Reply With Quote
Old 01-06-2008, 10:06 PM   #3
CyFi6
first one could be some kind of vac leak but it could be a million other things too like a sensor. Check the throttle position sensor.
Second thing seems pretty common, happens to me everytime i have a hot-restart, apparently its the fuel rail heatsoaking and initially spraying out vapors instead of liquid fuel, not a huge problem i dont think as it goes away pretty fast
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
