Old 01-07-2008, 04:02 AM   #1
WhiteTurboZ89
WhiteTurboZ89 is on a distinguished road
Default regular or synecthic?
hello, im really new to cars in general so plz excuse this newb question.
i went for a oil change today and my 7mgte motor was given regular oil instead of synecthic. i asked him why didnt i get synecthic, he said because my motor has 212,000 miles on it.
was he correct? any advice would be great thx
WhiteTurboZ89 is offline   Reply With Quote
Old 01-07-2008, 07:11 AM   #2
hardwire
hardwire is on a distinguished road
Well it may or may not depending on the condition of your engine seals. The detergents in the synthetic oils will "clean-up" the varnish and sludge left by conventional oils. If your engine seals are worn, the synthetic will break down the oil varnish that may be maintaining the seal. So it's not that the synthetic oil caused a leak, it just that it revealed worn seals by cleaning the varnish off of them. Many people have switched to synthetic on 100,000+ mile engines with no leaks, so it just depends on how often you changed your oil and the overall condition of your engine.
hardwire is offline   Reply With Quote
Old 01-08-2008, 04:16 PM   #3
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
my suggestion go back and bitch slap that guy and tell him u want synthetic next time, its better :P
im useing Royal Purple all throughout my car
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 01-10-2008, 06:12 PM   #4
xTomKx
xTomKx is on a distinguished road
Royal purple is like $8/quart so you are looking at almost $50 per oil change
xTomKx is offline   Reply With Quote
Old 01-10-2008, 06:32 PM   #5
Gunnar
Gunnar's Avatar
Gunnar is on a distinguished road
Synthetic, all the way.
Gunnar is offline   Reply With Quote
Old 01-10-2008, 06:33 PM   #6
Chambers
Chambers's Avatar
Yea, I use AMSOIL in my car, full synthetic, its like $6 something for a quart. I love it, great oil pressure, no leaks, no smoke, but I do have a JDM engine in it so the miles are quite lower than 200k plus.
"Stuck in the 80's"
Old 01-10-2008, 06:50 PM   #7
ethan12510
ethan12510 is on a distinguished road
I believe royal purple is like 6.99 at autozone.
ethan12510 is offline   Reply With Quote
Old 01-11-2008, 12:02 AM   #8
Supra2NR
Supra2NR's Avatar
synthetic all the way
i got a jdm motor which has about 60k miles
and i use mobil 1
and a regular oil change will b around 40 bucks
Old 01-14-2008, 03:06 AM   #9
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Default Synthetic
I changed the oil in mine when i got it. i got synthetic blend. I wanted the petroleum for the detergent properties, and the synthetic for the superior lubrication properties. after 2 or 3 changes that way, most of the gunk will be out, and i can put full synthetic in.
Synthetic is superior because;
  1. It doesn't break down into carbon & varnish like petroleum does
  2. Because it doesnt break down like petroleum oils, you can rev higher and run hotter without the oil loosing viscosity.
I got my supra because my last car needed more money than it was worth to be reliable. it has 274.000 miles on it and still runs great. MOBILE 1.
Irish_Mechanic is offline   Reply With Quote
Old 01-14-2008, 03:26 AM   #10
mkiiisupra
I use mobile one synthetic. First time i put the oil in i got a rear main seal leak was very minor, threw some barqs rear main seal stuff in there and after 300-400 miles the leak stoped, went ahead and changed out the oil and oil filter again after another 400 miles cuase i didnt wanna just leave that stuff in there
1990 Toyota Supra Turbo A/T
regular forum users car gallery suprra_girl Off Topic Forum 8 06-04-2008 07:40 AM
Regular, Supreme? SupraMax MKIII Supra 2 06-27-2006 01:13 PM
