Old 01-09-2008, 09:31 PM   #1
mkiiisupra
Default Rewired my knock sensors
In the guides it has you grounding out the wire on both ends, does this really help or is one ground on the intake penlum good?
1990 Toyota Supra Turbo A/T
Old 01-10-2008, 09:33 AM   #2
Gunnar
Gunnar's Avatar
Gunnar is on a distinguished road
One ground should cut it.
I did mine too, but i still get the error code, i guess i'm in for an expensive fix.
Gunnar is offline   Reply With Quote
Old 01-10-2008, 12:46 PM   #3
mkiiisupra
hopefully thats not the case for me, after looking at the connectors wire i would imagine that its definantly a bad connection. anyways ill find out tomorrow when i put my car back together and hook it up to the ecu
Old 01-10-2008, 07:15 PM   #4
mkiiisupra
for some reason my plugs that where on the knock sensor already had teh back of it filled down so i didnt have to remove the starter... but where all beat up and had some of the wire exposed almost like it was pulled on too hard and came out a little bit....
Old 01-10-2008, 07:39 PM   #5
Gunnar
Gunnar's Avatar
Can you take a picture of that filed down work?
I just bought a set of two and i'm gonna be changing them when they arrive.
I've heard stories of creating extra joints in your arm to be able to reach them without removing the starter :-)
Old 01-10-2008, 07:56 PM   #6
mkiiisupra
you just cut off the very back of the green plastic on one of the sensors, this allows you to put it on and take if off w/o removing the starter, if the ones on ur engine are not already like that u could probably just reach down there and cut off the back on the one thats on there..... just be carefull not to break the 250 dollar sensor lol
knock sensors and my build (PICS) toneloc87 2 MKIII Supra 3 07-12-2008 10:27 PM
replacing knock sensors and rewiring rocktownsupra21 Non-Generation Specific Questions 2 06-09-2008 01:25 AM
Knock Sensors?? Ebay?? blitzmkiii MKIII Supra 5 10-17-2005 03:57 PM
