Old 01-14-2008, 08:08 PM   #21
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Wow, sounds like you guys been burnin' that midnight oil! Are we close to figuring anything out? I had a question. In my experience, not to insult yours Irish, but doesn't white smoke mean coolant and blue means oil? Now here is just a suggestion, but the white smoke you saw when the car was started could probably have been condensation that was built up in your exhaust pipe, being that the car was sitting for a while. If not, I would say it's coolant. As far as timing is concerned, as Irish said before, the car was running, for 15 minutes! The timing isn't off. Even if it were a tooth of on the belt, which is more degrees than you can get by adjusting the CPS or calibrationg, the car would attempt to run, but die out. The first thing you should do in a no start situation is always check for spark and then fuel, in that order. You wouldn't want any fuel laying around a nice spark! Then you take it from there.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 01-14-2008, 08:12 PM   #22
mkiiisupra
New spark plugs installed recently, how do i check fuel?
Also new timing belt installed so it has not jumped a tooth
Read about a starter problem with the wiring, hesistant to start or sometimes you just hear the relay click but wont turn the car over. That 10$ part that lets u crank ur engine from the engine bay would that bypass that problem as a means to check if the wiring is bad?
Is there another way to go about this like running power straight from the battery to the starter?
1990 Toyota Supra Turbo A/T
Old 01-14-2008, 08:13 PM   #23
abhattan
abhattan's Avatar
Also, I'm not sure how it works with the NA's, but in order to set the base timing on these cars, you have to jump the diagnostic box. I am not sure which pins it is, but it's gotta be somewhere here on the forums. If all of your timing inputs check out, then I would look at the TPS or the MAF sensors.
Old 01-14-2008, 08:15 PM   #24
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Originally Posted by mkiiisupra View Post
Doesnt start with TPS disengaged, or at WOT
however now when i turn her over she just clicks and doesnt actually attempt to start.... I got one decent crank out of her with TPS off then after that wouldnt attempt to start
i think i drained the battery lol, can u check that with a multi meter?
the multimeter will probably only check voltage - what turns the starter is 'cold cranking amps'. places like NTB check it for free...but you'd have to drive there...if ur stick shift........popstart? maybe take a battery out of another car? really odd... if you have oil in the coolant or visa versa, have it towed to a shop for repairs to the head gasket... they'll need it to start before they give it back to you to verify repairs...if you didnt give permission for other repairs...they may be free.....
Irish_Mechanic is offline   Reply With Quote
Old 01-14-2008, 08:15 PM   #25
mkiiisupra
TPS checks out, you ahve to bridge connections in dia box to set timing but car has to be started to even check u...
But since u say it started so its not the timing idk..... what it is. Never had this problem before and all i did was clean throttle body, intake penlum, rewired knock sensor, calibrated TPS had codes 52/41 this fix cleard them both but now cannot start lol
Old 01-14-2008, 08:16 PM   #26
mkiiisupra
Head was recently done, there better not be any problems like that i will blow up the fucking shop who did the job lol. Especially if they tell me its not there fault lol
Old 01-14-2008, 08:30 PM   #27
Irish_Mechanic
as far as the condensation in the exhaust pipe putting out white smoke - if you've seen a steamer, you'll recognize that water vapor is clear. if you've seen the oil fields in the middle east ablaze(or a honda with shot rings) you'd recognize white smoke.
As far as putting power directly from battery to starter - there is an 8 guage wire running directly from battery to starter.
the clunking you're talking about could be anything - including lower end bearings (hope not)... vibrations like that may trip the knock sensors....
i think you're best bet is to get a mechanic to look at it. if you lived closer i'd come see, but as i'm just outside of philly...
Old 01-14-2008, 08:32 PM   #28
Irish_Mechanic
he is right in his diag procedure - spark then fuel, then compression..... however, most people go haywire checking sensors (me) well before busting out the compression tester... especially on cars that make changing spark plugs a pain in the ass...
Old 01-14-2008, 08:34 PM   #29
mkiiisupra
clunking? its like a click, the noise some relay makes in the supra everytime it does a start, its just that i only hear that it isnt follow up by the engine turning over
So not a mechanical thing since engine is not to the point of cranking yet
Old 01-14-2008, 08:54 PM   #30
mkiiisupra
How do you test the fuel system?
Prior to this my car would never crank the first time cold, took me try'n to turn over the engine twice then it would start up just fine. With engine warm it would start every time no problems.
I have suspected the fuel system before. New battery in car, and had advanced auto test alternator said it was good. New spark plugs, Diffrent spark plug wires. Vacumm lines all redone. So im at a loss as to what to do next
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
