Old 01-14-2008, 10:14 PM   #31
Pretaco
Pretaco is on a distinguished road
Back to basics.
You seem to have a handfull of problems and a very confusing problem.
Your click when starting is probably the starter contacts inside the starter. That is a common toyota problem. Just keep trying it until the starter turns over, jumping it will also help if your battery isn't fully charged.
Once you get it to turn over, pull a plug wire and hold it close to a body ground with a screwdriver pushed into the end of the wire, to check for spark between the screwdriver and the body ground, or "feel the spark"
If you get a timing light, hook it up to the #1 cylinder wire and even if it doesn't start, you will get a light and can check the base timing at the crank.
If those are both good, crank it for a few seconds and loosen the cold start injector, or any other pressurized fuel line and fuel should squirt/shoot out. Thats the easy way to check fuel pressure.
Get a stethescope and listen to the injectors as you crank the engine, they should make a rapid and pronounced clicking sound.
In my experience, white smoke is coolant, bluish white is oil, and black is fuel, but coolant and oil can be hard to tell apart, until you smell it, sweetish smelling smoke is coolant.
Even with a blown head gasket it should start, unless there is enough coolant leaking to hydrolock the engine, the engine will start on 3 cylinders. (ask me how I know that!)
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-14-2008, 10:32 PM   #32
mkiiisupra
Ok cool, good post. i will try this out tomorrow once i get off work tonight, I also reached out a botherd a neighbor lol very mechanically inclined and has a MKIV supra that he has done alot work to it, about 800 hp of work.
I would agree on the confusing part, i have had a loss of power issue with this thing forever and have fixed a great deal of problems, even taken it to diff places, including dealership for them to tell me they have no idea what is wrong....
I thought it was becuase of the knock sensor and TPS and that ecu was retarding the timing or w/e cuase had a bad signal from them but the 15mins i got to drive her, she still had that loss of power BAH!! maybe next 2 days i will figure it out
1990 Toyota Supra Turbo A/T
Old 01-15-2008, 06:49 PM   #33
mkiiisupra
Problem solved????
Went out decided to give it one more go.
Checked fuse box, went ahead and replaced the 15A fuse for the EFI even tho it still looked good.... started her up she cranked isntantly
like faster than she ever has before .... lol
Old 01-15-2008, 08:11 PM   #34
Irish_Mechanic
Irish_Mechanic is on a distinguished road
keep a few more of those fuses in the car! dunno why she blew, but in case she does again...
glad u got her running
Irish_Mechanic is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
