Old 01-14-2008, 12:07 AM   #1
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Default Turbocharging an N/A Motor
I'm getting parts together to turbocharge my 88 N/A. I plan to use a stock turbo manifold, a stock turbo, intercooler, and other turbo related parts. Most cars, from my experience, can handle 5 to 7lbs of boost with stock air metering and fuel injection equipment. While i dont plan to run the boost higher than 7 lbs, i would like to know if anyone else has done this. I dont plan to swap the motor or even just the cams. If I get fuel cut I'm prepared to get an aftermarket MAF translator and possibly upgrade the part of the fuel system thats bottlenecked, beit the pump, or injectors.
If anyone's done this and has advice, it'd be appreciated. I'd like recommendations and vouches for distributors of these parts.
Thanks!
Irish_Mechanic is offline   Reply With Quote
Having trouble getting motor separated from tranny... shawn87gta MKIII Supra 15 05-08-2006 05:16 AM
Motor Mounts chrisr3344 MKIII Supra 1 01-30-2006 02:54 AM
