Old 01-16-2008, 04:18 AM   #11
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
did you plug in the afm?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 01-16-2008, 10:36 AM   #12
binxy69
binxy69 is on a distinguished road
Red face
I've tried all sorts with it, but its looking more and more like the AFM has had it. I've ordered another one from a breakers that has a warrentee on it (?75 :-( ) but at least if it doesn't work I can send it back and assume I hav another problem.
However I'm getting all the right voltages down the wiring and even after the connecter inside the afm, so really I think I've eliminated all other possibilites.
It should turn up today, but if it doesn't cure this problem, I will be royally stumped.
Cheers for your help guys, I'll let u know how it goes.
binxy69 is offline   Reply With Quote
Old 05-01-2008, 08:56 PM   #13
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
i think im having the same problem
but the K&N filter is really screwed up so thiers a new metal one
is thier anyway to test if its the cables (the ones i cant reach because my hands arnt small enough)
because i sprayed the Air Flow Sensor with that spray for it so its clean and a new air filter
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
Old 05-01-2008, 09:18 PM   #14
supramacist
supramacist's Avatar
DRY FLOW FILTERS Gents.
I like to dis-connect both terminals for atleast 15 minutes to make sure that
The battery and the ecu have both had ample time to adjust.
It's like re-booting your pc. Sometimes you need to leave it off for a spell.
That's about the going rate here in the states for a reman'd vafm.
You should also check your timing.
Keep checking for codes. Don't idle up or you'll automatically throw a 51 and that'll be your tps.
Old 05-01-2008, 09:44 PM   #15
Bill UK
AEM EMS
Bill UK's Avatar
Originally Posted by binxy69 View Post
1. I'm a student at brighton uni so money isn't something in huge supply
2. I dunno if it even broken yet lol
Hi binxy 69, I live in Steyning, West Sussex.. Just down the coast from Brighton. Small world!
Old 05-02-2008, 03:32 AM   #16
SuperSpartan
my codes? well i came up with a 21 i think? flash flash flash.......flash
something to do with airflow
everythings fine just making sure its the mass air flow sensor
