View Poll Results: Bic DDP on street? | |||
Yes, easily |
1 | 50.00% |
Yes, if you go easy on it. |
0 | 0% |
Not if you don't like paying tickets. |
1 | 50.00% |
No way! |
0 | 0% |
Multiple Choice Poll. Voters: 2. You may not vote on this poll |
Thread Tools | Display Modes |
#1 |
How many of you with the bic DDP daily drive your cars?
How loud is it and can you drive it without getting tickets for noise? I really think thats what I want to put on my car, but not if I can't drive it on the street. I also have to pass emissions every two years, so need something that will pass a smog and visual test. I'm not too worried about the visual, I doubt they will be able to see anything under there, but I don't know how close they look. I don't want to do the optional reconnection back into the exhaust, because I want the exhaust noise, but only when I floor it. So I guess I want to know how loud is it before full boost, and can you control the sound by the way you drive? Thanks, Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE ![]() Currently Running Good ![]() ![]() ![]() For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual. Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc.... |
#2 |
Well I can't help you with the exhaust but I can give you some advice about the emissions. If you have a good cat, 02 sensor, and not running to rich, then you should pass emissions, but I don't know how strict they are in your state. As for the visual inspection, as long as you don't have a test pipe in they should be able to see the cat and pass you on that. Good luck!
#3 |
It is loud, the way it seperates the waste gate from the main flow is only a little peice of metal...
So even when waste gate is not opening some air gets down thru the other opnening. My car sounds alot nicer.. Its not too bad when ur just cruising around but if u hit it, and ur waste gate opens.. Its pretty loud My state ha s no emissions so idk about all that
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
Thread Tools | |
Display Modes | |
