01-29-2008, 09:15 AM | #21 |
wel atleast you could of driven your car for a while, i noticed that the engine had almost no power when i just drove it from the previous owner to my house.... deal was made no refunds so i was stuck there next time il make a investigation before buying a car that cheap with the owner saying it runs "perfect"
01-29-2008, 09:19 AM | #22 |
Lots of pain i think come along with these things, people didnt take care of them, jimmy rig it to barely run then cash out >.<
Just glad i had no cosmetic/frame/rust damage.
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
01-29-2008, 09:24 AM | #23 |
i think its just sad for ppl not taking care of theyre cars.... i love supras thats why i bought this one as a start im now looking for a '97 supra
01-29-2008, 09:25 AM | #24 |
How did your weapon R intake work, any pictures?
01-29-2008, 09:29 AM | #25 |
didn work at first cause of the heat of the headers.... we had drilled the intake close by the throttle body to see the temp of the air going in with a intake sensor, at that location you know the estimate of the temp(i think)... with the weapon r its made of aluminium so it conducts heat and the temp was up by almost 50 degrees.. thats y i went and got the coat and wrapped the headers and il take pics and send it to you when i can... with it installed did notice a slight faster response on the engine but dont know by how much because i used to have a chrome tube and had a so called small supercharger in it which made a huge difference when it was without it so now with the new intake without the supercharger its a dificult to know
01-29-2008, 09:36 AM | #26 |
Going to hook up my AEM dryflow soon and cooleeze IC pipes.... going to see how much a diff it makes and if imma need to run the filter to a cooler spot or not.
Currently just have the drop in K&N she felt a lil quicker after that.. very minimal though
01-29-2008, 09:41 AM | #27 |
the small supercharger is just a small fan that starts spinning when u start up the engine. when the engine is running at high rpm it makes the fan spin faster. when u let go of the gas the fan keeps spinning without losing the speed fast and when u press the gas it inmediatly gets air "pushed" in by the little fan which gives u a faster response, a little bit of hp increase and u get more mileage out of it... it just sits in the intake tube no wires or anything... the weapon r intake consists of another pipe in it that is why i cant use the lil thing
01-29-2008, 09:42 AM | #28 |
get a heat shield for it maybe that will help or use a longer pipe to get it more up front further away from the engine
01-29-2008, 09:46 AM | #29 |
this thing?
01-29-2008, 09:50 AM | #30 |
nope that just sits still.. the blades are a lil sideways which makes the air like spin around in the intake... by that the airflow doesn lose speed
i am talking about this thing.... only usable in N/A cars.... if you have a turbo then this wont help Last edited by SilenceboneSupra; 01-29-2008 at 10:03 AM. |
Similar Threads | ||||
Aftermarket intakes? 7M-GTE? | Boombastic | MKIII Supra | 0 | 11-26-2008 10:40 PM |
SUPRA LSDs AND COLD AIR INTAKEs QUESTION | C0o0n | Non-Generation Specific Questions | 2 | 08-10-2008 02:33 AM |
Cold-air / short-ram intakes | nickvash0104 | MKIII Supra | 1 | 08-25-2005 06:24 PM |
