Old 01-18-2008, 04:34 PM   #1
Pretaco
Pretaco is on a distinguished road
Default Its Alive!!!
I finally got all the parts I needed and got that damn engine running.
Had a weird problem though, the injectors were not firing due to the computer not grounding them. So I figure I need a computer, all the power circuits were good and all the gound ones too, I had spark, and all other signals tested good. So on a whim, I grounded the case of the ecu, and bam, it fired up instantly! I then took off the ground and it still runs great. I have no idea why or how, but who cares.
Its pretty loud with 4' of 3" exhaust. I'm going to try and get some pics up soon.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
It's Alive tellfromchico,ca Show n Tell 9 11-15-2006 03:49 PM
Its Alive And Runs Great! GreenChevelleSS MKIII Supra 16 01-11-2006 02:07 PM
