Old 01-21-2008, 07:19 PM   #1
adknight87
adknight87 is on a distinguished road
Default Random Fludder during Idle
Stats
7M-GE 86.5'
Problem: When Idling it gives a fludder randomly but returns to normal. When giving it gas it seems to be non existant.
My Guess: It would probably be the intake manifold or along the lines of that.
Any ideas?
adknight87 is offline   Reply With Quote
Old 01-21-2008, 11:53 PM   #2
f00g00
When my car had a random sputter at idle it would seem like it wanted to shut off but would recover. The rpm would drop 200 - 300 or so. Turns out the connector on the TPS was half on scince my connector lock is broken, so check that and the other connections like AFM and ISC.
Old 01-22-2008, 02:44 AM   #3
adknight87
Default Lost
Break it down dummy style although I love the supra like its a part of me some parts I have no clue about. Sorry if this inconvenience's you. I just want to learn more about the car so I can restore it.
Old 01-22-2008, 04:09 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
TPS= Throttle Position Sensor
AFM= Air Flow Meter (aka Mass Air Flow Sensor)
ISC= Idle Speed Control
On the top of your engine, at the throttle body (where the cable from the driver's side of the car links to the engine), there is a sensor with a plug coming out of it. The plug is typically black, and has 4 wires going into it. That's your TPS and plug. Make sure it is connected well.
At the top, front of your intake manifold near the crankcase oil cap is another sensor. I can't really describe it very well, but it has a 6 wire plug coming out of it. That's your ISC and plug. Makes sure that is connected well.
Off of the engine at the passenger side of the car is your intake piping. At the end farthest from the engine, right before your air filter, there's a bulky box-looking thing that the air goes through in the piping. That's your AFM. Make sure the plug on that are also connected well.
Just thought I would simplify what was afore stated for you, although I don't believe I can contribute any additional advice.
Old 01-22-2008, 06:30 AM   #5
adknight87
Default Thanks
Thankies, I guess I will keep ya posted on it once I get it lol. it will be a couple of months before I get to work on it totally.
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
1987 Toyota Supra Idle spycialost9999 Non-Generation Specific Questions 3 06-14-2006 06:33 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
