Old 01-20-2008, 08:40 PM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
Default need help quick
ok well i just put in a new hks metal headgasket and new valves stem seals put everything back together by the book and now if my car is dead cold i can start it right up but if i shut it off it wont turn back on no matter how many times i try and sometimes if i get it started and let it warm up a little i go to turn it off and literally when i turn the key to the off position the car stays running?? weird right?? could all of this be due to cps alignment if so could some pleaseeee tell me how to properly put in the cps and do the timing thanks so much
cyanide-is-a-way-out is offline   Reply With Quote
Old 01-21-2008, 07:20 AM   #2
89wna
89wna's Avatar
89wna is on a distinguished road
Timing Is Possible. Check Your Cts As Well.
89wna is offline   Reply With Quote
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
new to forums... some quick Q's gfx MKIII Supra 3 10-12-2005 01:54 PM
