Old 01-25-2008, 04:25 AM   #1
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Default Electric Fan Controller Temp. question
since the fan shroud of my '92 supra was broken and couldn find any replacement i decided to go get 2 Hayden 3690 electric fan for my car. i got a new radiator and the fans fitted nicely on it, afterwards i went and got a Hayden Thermostatic Electric Radiator Fan Controller for the fans.
The controller can be set between 160F - 230F.
My question is at what temp should i set it?
SilenceboneSupra is offline   Reply With Quote
Old 01-25-2008, 06:15 AM   #2
OfnaRcR
OfnaRcR is on a distinguished road
200? I'm not sure.
OfnaRcR is offline   Reply With Quote
Old 01-25-2008, 04:09 PM   #3
Pretaco
Pretaco is on a distinguished road
I just set my electric fans up to the factory switch on the thermostat housing. If you want the temps that it uses to turn on and off, check the repair manual under the air conditioning section, under system operation it will give you the temps used to turn on and off the fans. I'm thinking of getting some pics and doing a writeup on how to use the factory switch and relays to control aftermarket fans.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-25-2008, 04:15 PM   #4
Pretaco
Actually its kinda hard to find if youre not familiar with the factory repair manual and the ewd. This is the page of the ewd that has the temps:
http://http://www.cygnusx1.net/Supra...x?S=Main&P=145
They turn on at 212°F, and off at 203°F.
The 212°C is a misprint.
Old 01-26-2008, 04:11 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
I don’t think that link is working Pretaco, try these.
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=CO&P=3
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=AC&P=33
Old 01-26-2008, 08:17 PM   #6
btwilson86
Super Moderator
btwilson86's Avatar
And here's the original link... had an extra "http" in it:
MK3 TEWD On-Line
Old 01-27-2008, 03:29 AM   #7
Pretaco
So I can't link stuff!
Its the thought that counts!
Thanks for clearing that up though.
Ray.
Old 01-28-2008, 03:02 AM   #8
SilenceboneSupra
well if on the EWD page is right then the controller is no use to me!
the temp on the page is between 104F - 140F and the controller can only be set between 160F - 230F or am i assuming something wrong here??
correct me if im wrong please
please do remember that the car has a 7m-ge engine
Old 01-28-2008, 04:52 AM   #9
Pretaco
The temps on the page say "on" at 212°F, and "off" at 203°F.
It doesn't matter what engine you have, just that the only supra that had the electric fan from the factory was the auto tranny turbo car. (Engine coolant temp fan.)
The 104-140° is for a different water temp sensor, I think it has something to do with the heater. I just can't figure out exactly what.
Ray.
Old 01-28-2008, 08:26 AM   #10
SilenceboneSupra
isnt that a little bit to hot, ive been working on cummins engines which are big v16 twin turbo engines with 1800hp at 1800rpm they are not to go higher then 2000rpm and they cant get hotter then 194F otherwise its ECU does a emergency shutdown on the engine.....
at those on the page the water would be almost boiling at that temp....
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
How to install a oil temp controller ? Supra-Iceman Non-Generation Specific Questions 4 01-30-2007 11:18 PM
Temp. Sender-what does it do? Benesesso MKIII Supra 2 05-10-2006 03:06 AM
