#1 |
eBay Motors: 1JZ 2JZ 1JZGTE 2JZGTE V-Band Turbo 3" Downpipe Supra (item 330206583758 end time Feb-01-08 19:07:13 PST)
do any of you think that this DP will work with my 7MGTE, i have gotten a new turbo with the v-band and i need a DP that has a Wideband plus our stock heated 02 bunges. so i was wondering if it would clear the firewall?
![]() 7MGTE - 500hp ![]() exhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
#2 | |
could possibly work, you can also try bicperformance.com they make really good downpipes
89 white package twin turbo Quote:
#3 |
I am very happy with mine, i got the BIC downpipe with divorced wastegate... full 3" exhaust with a 1.75" pipe for just the wastegate on the CT-26, sounds really nice when the waste gate on the turbo opens up. Still have stock exhaust from that point on and it changed the sound of my car to a deep rumble
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
#4 |
well i need one that is 3inch, v-band flange "not ct-26" and a bunge for stock 02 sensor and a wideband. and maby the addition of a external wastgate pipe
#5 |
well has the stock o2 sensor flange and u can have them put a wideband on on there, however i guess wont fit up to what u have srry
