Old 01-28-2008, 06:25 PM   #1
zambini
zambini is on a distinguished road
Default slow crank when starting..
hey guys,
when i start my car (90 turbo) it seems kind of reluctant to turn over.. nothing too crucial- it starts every time, but it sounds really slow and drawn out.. definitely not healthy sounding. I just replaced the battery, and the problem still persists. The battery cables are looking pretty haggard, like someone has rewired them with a skinnier gauge wire some time in the past. I'm not sure if too thin of a wire would not allow for as many amps when starting or what.. I'm also thinking the starter itself maybe?
Once the car is started, it's fine though. The alternator should be in good shape, since it does start every time, and the brightness of the headlights never dims.. I'm about to replace the plugs and wires some time this week to see if that helps.
any advice would be appreciated!
thanks,
aaron
zambini is offline   Reply With Quote
Old 01-28-2008, 08:14 PM   #2
supramacist
supramacist's Avatar
YA sounds like a resistance issue.
That's pretty much what happens when stock cables get green and nasty on the inside. It isn't propperly pulling the plunger on the starter because the amps are being drug in slowly.
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
Slow Start jaysun MKIII Supra 5 09-18-2006 07:36 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
