#1 | |
![]() Quote:
#2 |
Super Moderator
I had actually just run into the same problem with the TPS... I got one of the newer sensors (with the metal exterior as opposed to plastic) from a local pick a part (fits in the pocket, so you can't beat that price). Got home and found out that the interior's of the sensor were different. After thorough inspection and a little reading, found out resistances are the same for all the TPS's, just design difference. So I went and picked up a newer TB to go with my sensor (as I couldn't find an older sensor), calibrated it and installed it on my engine, and *VOILA* TPS CEL goes away.
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#3 |
the old on i have seems more sturdy, the interior parts are metal where as the newer ones 89+ are plastic on the inside.
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
#4 |
Super Moderator
I might have had the age mixed up on the one's I was describing... Either way, metal is better. My plastic one's interiors melted (maybe when I overheated and blew my first motor). I don't see that happening with the metal parts in the TPS.
#5 |
I have had no compatablility problems with running a 90 ecu on a pre 89 engine.
Seems like yeah maybe diffrent parts but they all send they same signals to the ecu
#6 | |
![]() Quote:
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
1990 supra turbo engine issues help | jespat | Non-Generation Specific Questions | 4 | 01-24-2008 02:37 AM |
Engine Mounts 1990 7M-GTE | Bill UK | MKIII Supra | 2 | 08-17-2006 01:43 PM |
1990 to a 1989 swap | jaysun | MKIII Supra | 0 | 08-15-2006 06:59 PM |
