Old 06-21-2005, 04:29 AM   #1
teh86point5
teh86point5 is on a distinguished road
I've owned two MK3's, both of which the speedometer didnt work at all. I checked out the fuses, but I suck when it comes to wiring. Anyone else have this problem and could spare some advice?
Thanks,
Chris
White, N/A MKIII
teh86point5 is offline   Reply With Quote
Old 06-21-2005, 04:30 AM   #2
teh86point5
Also, the gauge lighting is non-existant. Brand new fuses as well, I think my whole guage clusters wiring is just out of wack.
White, N/A MKIII
Old 06-21-2005, 06:22 AM   #3
mrnickleye
mrnickleye's Avatar
What year? My '89 Speedo uses a cable.
Old 06-21-2005, 10:56 AM   #4
ddmcse
ddmcse's Avatar
check by your left knee (assuming you have a left hand driver) there is an adjustable dial for the gauge lights "a dimmer" it might be turned off
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-21-2005, 01:42 PM   #5
KingDiamond
KingDiamond is on a distinguished road
i'm assuming you have a digital dash the way your talking, supra girl would the one too talk to for that, i remember one of her posts had something to do with a digital dash fic. If its not digital let us know, well go from there.
KingDiamond is offline   Reply With Quote
Old 06-22-2005, 05:37 PM   #6
teh86point5
I've tried the dimmer, and no my dash isn't digital. The speedometer needle is just dead, and the nighttime lighting for the dash doesn't work.
White, N/A MKIII
Old 06-22-2005, 05:55 PM   #7
KingDiamond
you might have just gotten two supras with broken speedo cables, or shot gearing at the end of the cable where it attaches into the trans housing.
Old 06-24-2005, 01:38 AM   #8
teh86point5
what's your guess on the price to get that fixed, or would it be an easy fix to do myself?
White, N/A MKIII
Old 05-03-2006, 04:46 PM   #9
Isphius
Isphius's Avatar
Let me know too....same problem haha. It seems to be a very common problem in Supras. I have every common problem, leaking power steering ,no speedo, failed emmisions, Dome lights dont work....etc. haha.
Old 05-04-2006, 10:48 PM   #10
j3pz
the speedo cable is more than likely to blame. mine went out like a month ago. let me know about how much it will cost... as for the lights, id check to make sure the wiring is hooked up then id check the bulbs themselves.
speedometer drive gear removal Gunnar MKIII Supra 1 01-20-2008 08:24 PM
Speedometer and boostgauge not working Gunnar MKIII Supra 0 10-20-2007 08:17 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
Speedometer help HottScennessey MKIII Supra 1 03-19-2005 06:59 AM
