Old 02-05-2008, 04:51 PM   #1
mkiiisupra
Default Vacuum line routing to HKS SSQV?
Is this the proper route for the HKS, i just used the factory BOV line.
Or do i need to run it from a different location? If so do i just cap off the old bov line?
1990 Toyota Supra Turbo A/T
Old 02-05-2008, 05:11 PM   #2
SilenceboneSupra
SilenceboneSupra is on a distinguished road
that just looks sweet..... idk bout the vacume line tho
SilenceboneSupra is offline   Reply With Quote
Old 02-05-2008, 06:15 PM   #3
mkiiisupra
hahaha thanks, thing is while driving around i couldnt really hear the BOV open up. Well heard a slight whistle, wasnt well defined and was pretty quiet. Perhaps taht was it... or i was hearing my intake...
Not boosting very high right now only about 4-5psi, dont want to turn it up till i get the rest of my pipes on, dont know if that has ne hting to do with it
Old 02-06-2008, 02:55 AM   #4
SideWinderGX
SideWinderGX is on a distinguished road
ooh, id be interested in what people have to say here. this is what im getting, plus the recirculation kit.
eventually.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 02-06-2008, 03:16 AM   #5
mkiiisupra
figured id start off w/o the recirculation kit, and if i saw ne problems order it. Ill let you know if i do
Old 02-06-2008, 04:00 AM   #6
SideWinderGX
sweet, thanks. there shouldnt be any problems cept for running really rich and a lack of boost right after shifting as far as i know.
my car:
Old 02-06-2008, 04:35 AM   #7
mkiiisupra
ya. don't think i have really heard it kick off yet. slight whistle a low speeds but nothing other than that.... Not sure how much nois it is supposed to make.... but only boosting like 4psi right now
Old 02-06-2008, 05:07 AM   #8
j3pz
should recirculate that. its releasing metered air to the atmosphere. like already said, you'll run rich
Old 02-06-2008, 05:29 AM   #9
Pretaco
Pretaco is on a distinguished road
Yes, that is the correct vacuum routing. The aftermarket bov, use the same line as the factory cbv's. I run mine to the atmosphere, and it will backfire due to raw fuel when you shift real hard at high boost and rpm, but otherwise shouldn't be a problem. Might burn up your cat with that much raw fuel, but for those short periods of time just after shifts at high boost, I don't think it will be much of a problem.
I guess I will find out when I have to do emissions next year.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Where is this vacuum line saposed to connect to? mkiiisupra MKIII Supra 15 07-15-2010 05:15 AM
Vacuum line help 91toy supra MKIII Supra 7 08-25-2006 11:32 PM
Vacuum Line Deletion? Bullz_EyE MKIII Supra 1 12-24-2005 06:37 PM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
