Old 02-13-2008, 05:59 AM   #1
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
Exclamation Changing head gasket questions???
I just removed the head from my 7m and this is what I saw. It looks embarrassingly horrible. If anyone knows or thinks they know where it may have came from I'm all ears.
Paul[IMG]file:///C:/Documents%20and%20Settings/paul/Desktop/13022008%28005%29.jpg[/IMG][IMG]file:///C:/Documents%20and%20Settings/paul/Desktop/13022008%28003%29.jpg[/IMG]
ID:	1256   Click image for larger version
ID:	1257   Click image for larger version
1990 3.0Ltr GT Turbo @8psi Manual (Converted)
linuxgurupodboy is offline   Reply With Quote
Old 02-13-2008, 09:12 AM   #2
rayshawn.434
rayshawn.434's Avatar
rayshawn.434 is on a distinguished road
i cant see a good pic of it but is all the pistions like that?
rayshawn.434 is offline   Reply With Quote
Old 02-13-2008, 09:31 AM   #3
linuxgurupodboy
Yeah, it feels like a sandy gritty substance, comes off easy.
Old 02-13-2008, 09:49 AM   #4
rayshawn.434
Thumbs up
if it black its just carbon build up i would just clean it off and dont worry about it. as long as it did not do any damage to the pistions like deep cuts
Old 02-13-2008, 01:46 PM   #5
j3pz
nfi what it is. didnt come over the bottom of the head did it? is it metalic?
Old 02-13-2008, 04:27 PM   #6
Pretaco
Pretaco is on a distinguished road
What were the syptoms before you took the head off?
What does the bottom of the head look like?
From those pics, I would say look at the cylinder walls closely for vertical scratches, and see if the crosshatching pattern is still visable in any of them.
I would also suspect that the head gasket was bad between the #5 & 6 cylinders from the clean spot between those cylinders, but the #6 piston still has carbon build up, so no coolant was getting in there.
But those pics are pretty crappy to be honest.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 02-13-2008, 06:05 PM   #7
linuxgurupodboy
Sorry guys bout those pics, will get better ones tonight.
I was driving from Auckland to Hamilton, bout 200 kilometres. 3/4 the way down I ran out of water, temp got right up there. Anyway filled it back up slowly while engine was running. I was driving home from work the other week 30 kilometres and temp got right up there again, but once I got the radiator cap off, found it still was 3/4 fill. Once filled up, I noticed small air bubbles surfacing from radiator while enigne was idling.
Old 02-13-2008, 06:16 PM   #8
Pretaco
Are any of the pistons or cylinders or valves much cleaner than the others?
The coolant leaking into the combustion chamber will usually clean whichever cylinder that is bad, but maybe not if it was a small break and you didn't drive on it very much.
Pics of the bottom of the head, or of the gasket itself might help. Only if you were careful while removing the gasket.
Ray.
Old 02-18-2008, 04:46 AM   #9
linuxgurupodboy
I finally got round to taking more pictures, hopefully these will be good enough to make judgement. I just turned the head over for the first time to inspect it and found two inlet valves had some type of strands of grey fibre or linen stuck in it, could it be part of the head gasket?
ID:	1266   Click image for larger version
ID:	1267   Click image for larger version
ID:	1268   Click image for larger version
Old 02-21-2008, 01:24 AM   #10
ddmcse
ddmcse's Avatar
Cool
what distro do you use ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
