Old 02-14-2008, 02:29 AM   #1
mkiiisupra
Default Code 34
34 Turbocharger Pressure Diagnosis
  • The turbocharger pressure is abnormal.
Trouble Area
  • Turbocharger
  • Air flow meter
  • ECU
  • Intercooler system
Right so i got this code after doing a pull to 100mph. I guess i hit fuel cut? or is this something else. Have a 1/4" spacer on the actuator
1990 Toyota Supra Turbo A/T
Last edited by mkiiisupra; 02-14-2008 at 04:40 AM. Reason: 1/4" spacer not 1/2" heh
Old 02-14-2008, 05:02 AM   #2
Pretaco
Pretaco is on a distinguished road
Too high boost pressure due to a disabled waste gate could definetly cause this code. I would reset and not worry about it, unless it comes back, then take out your spacers and see if it comes back a third time, if it does, then worry about it.
Until then have fun with the 12psi!
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 02-14-2008, 05:47 AM   #3
mkiiisupra
Thats what i thought.... may need take down the spacers but 12 psi is nice erm...
Need to do the lexus AFM upgrade hehe.
Old 02-15-2008, 01:22 AM   #4
j3pz
dont forget the 550's
Old 02-15-2008, 12:29 PM   #5
mkiiisupra
prolly need to get fpr as well, ive heard stock doesnt hold up to well to 550's
I have heard alot about idle problems, is that just a problem with tuning the MAF or all of em
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
