Old 02-17-2008, 03:13 AM   #1
tcrawman
tcrawman is on a distinguished road
Default 86.5 Manual non-turbo will not start!!
This is the second time in a month this has happened. I get in the car turn the key and nothing. All the lights come on, radio comes on but there is no crank or anything. I've tried to arm and then disarm the factory alarm but still nothing. Anyone have any ideas?
tcrawman is offline   Reply With Quote
Old 02-17-2008, 06:29 AM   #2
CyFi6
Any click noise or anything from the engine bay area? Usually if there is 0 noises anywhere its the alarm, sometimes you gotta try to ar/disarm it a few times.
Old 02-17-2008, 02:49 PM   #3
tcrawman
Got it started this morning. Apparently a wire came out of the factory alarm, probably the start signal to the ECU. Tried to unplug the alarm but the car wouldn't start. Plugged it back up and it started fine. I need to go to the dealer to get the schematics for the alarm and figure out which wire is the start signal and bypass it to just get rid of the problem all together. thanks for your reply
Old 02-18-2008, 11:35 PM   #4
stewie
stewie is on a distinguished road
Default electrical drawings
If you hav a fax/e-mail, i could could send you the diagrams i have for a 1991 non turbo. files to big to post after scanning
stewie
stewie is offline   Reply With Quote
Old 02-19-2008, 02:07 AM   #5
carfanatic89
carfanatic89's Avatar
Yeah the alarm computer and the ignition are wired to a relay and the alarm comp. allows current to travel through the relay to ground and the circuit for the ignition is swtiched on to the starter
heres the alarm wiring diagram
MK3 TEWD On-Line
Supra Engine Powered Dragster
Old 02-19-2008, 01:41 PM   #6
tcrawman
Default Beautiful!!
Thanks for that link, that will help a lot
89 7mg to 2jz turbo manual turbojuiced MKIII Supra 2 04-05-2008 01:11 AM
86.5 Manual non-turbo will not start!! tcrawman Non-Generation Specific Questions 5 02-18-2008 04:59 PM
