Old 02-19-2008, 04:52 PM   #1
1986.5 targo
1986.5 targo is on a distinguished road
Question 1986.5 na 5spd not starting help..
So i parked the car went inside for about half an hour came out tryed to start it, and all i get is the starter relay clicking and the normal lights that come on.. i replaced the starter; not that i checked all fueses none bad checked the clutch switch thats still good.. If anyone has any ideas please let me know this is driving me crazy...
1986.5 targo is offline   Reply With Quote
Old 02-19-2008, 07:05 PM   #2
1986.5 targo
oh but also if i push the car and pop the clutch it starts right up
Old 02-19-2008, 07:34 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Sounds like your battery died on you. Pop the clutch, drive to AutoZone, have them do an on vehicle check of your battery and alternator. It's free. But I doubt it'd be your alternator if you can pop the clutch to get it going.
On second thought, you could also find a friend or neighbor to help you jump start it. If that works then I'm pretty sure it's your battery, but you should still go get it checked out.
Old 02-20-2008, 02:33 AM   #4
1986.5 targo
yeah i thought of that too.. i tryed having it jumped but sadley still nothing.. anyone got any other ideas?? I need all the help i can get.. thanks...
Old 02-20-2008, 02:34 AM   #5
supramacist
supramacist's Avatar
Pull the starter and have it checked and or pull the codes.
Old 02-20-2008, 02:51 AM   #6
1986.5 targo
the starter is new and the only code that is pulling up is 51 but i dont think that would stop the car from starting... Any help with this problem would be grate... Thanks
Old 02-20-2008, 06:03 AM   #7
btwilson86
Super Moderator
btwilson86's Avatar
Have you checked how well the car grounds from the battery? Do the instrument lights and such turn off after the starter clicks?
Old 02-20-2008, 06:50 PM   #8
supramacist
DO you hear the starter winding up??
Check your fuses. I have personally bought bad starters.
To go home put them on and have to pull them and test them.
It's rare. But it happens.
Old 02-21-2008, 12:56 AM   #9
1986.5 targo
Ok so i fixed the problem.. The car wasnt grounded enough I ran ground wire's from the starter bolt, the tran, and the intake to the negitive on the battery and it started right up.. sounds like it runs better too.. the rpm is now at a solid 1500 everytime... thanks for all your help..
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
