Old 02-21-2008, 12:05 AM   #1
mkiiisupra
ya i just noticed it after i took off the intake and spark and thorttle body lol
1990 Toyota Supra Turbo A/T
Old 02-24-2008, 03:36 PM   #2
mkiiisupra
Redid the compression test these are the numbers i go
Cylinder #| First needle movement | Max Compression |
1 | 80 | 171
2 | 90 | 170
3 | 80 | 173
4 | 80 | 171
5 | 80 | 176
6 |80 | 171
Old 02-24-2008, 08:12 PM   #3
CyFi6
Make sure you disable fuel and hold throttle at wot (unless you had to remoce the throttle body to get to theplugs anyways. Excessive compression can be cause by many things such as carbon buildup in the cylinders or just have the head shaven down enough
Old 02-24-2008, 08:39 PM   #4
mkiiisupra
bah. looks like i will be doing another test lol
Cant seem to do it right, forgot to open throttle up >.<
How do you disable the fuel?
Old 02-26-2008, 11:27 PM   #5
mkiiisupra
bump. do i just pull the EFI fuse to disable the fuel system?
Old 02-27-2008, 12:35 AM   #6
CyFi6
That should do it
Old 03-01-2008, 12:21 PM   #7
ddmcse
ddmcse's Avatar
Cool
yes ..
i'd say your compression is fine
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-01-2008, 12:32 PM   #8
mkiiisupra
ok good, that will keep me from doing it a 3rd time lol thanks guys
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
WOW did a compression test now i got code 12 n 14 help 88Tsupra MKIII Supra 9 06-30-2007 08:19 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
what are factory compression test numbers? 2JZEFINI-17 MKIII Supra 1 11-05-2006 11:58 PM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
