Old 02-29-2008, 03:50 AM   #1
suprascoot
suprascoot is on a distinguished road
Default Car alarm with a mind of its own
Hello all,
Ive got an 89T Automatic with an alarm that randomly goes off. I goes off when locking the car from the inside, outside, or locking the inside and holding the handle up while closing the door. I think one of these activates the alarm while the other does not but I don't know which is which. I am at the point, as are the people who have to sit and listen to my car alarm, where i just want to rip the dam thing out.
My question comes here...has anybody successfully done this. Being the alarm system is connected to so many other electrical systems throughout the car, I have the haunting suspicion that it wont simply be unplugging a little computer.
Anyways any help will be greatly appreciated
suprascoot is offline   Reply With Quote
Old 03-03-2008, 12:22 AM   #2
01010011
01010011's Avatar
01010011 is on a distinguished road
Default wow thats kinda odd
it sounds like someone wired the alarm wrong.. :-\ thats never fun have you looked in the haynes book for a wiring diagram? or something?
um what was i saying? 0_0..
01010011 is offline   Reply With Quote
Old 03-04-2008, 12:05 AM   #3
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
It might also be that some messed with the setting on the box. Check underneath the drivers side dash in the footwell. Cant remember at the moment if its on the side next to the door or underneath the dash. I know of cases of some people that have kicked the box on accident and it actually moved the sensitivity up all the way to the highest setting. Check on that.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 03-04-2008, 12:16 AM   #4
ravenmaster
Check ot this site here: www.SUPRAS.com - Member's Section
it has a bunch of nice litle mods and other things i believe it also has resolutions for the alarms.
Old 03-04-2008, 03:01 AM   #5
suprascoot
thats the weird thing about this...I have owned the car for nearly 8 years doing all repairs myself, sometimes learning in the process. I have never had any problems with the electrical system until this alarm. Not sure if it might be a failed alarm computer or something. To make things worse, the problem is intermittent so it is even harder to diagnose.
Old 03-04-2008, 04:05 PM   #6
ravenmaster
Did you take a look at the site? I think I found a resolution for your issue on there....
Old 03-05-2008, 01:55 AM   #7
suprascoot
hey ravenmaster,
thanks for the referral, I did find some helpful information concerning the wires running to the door lock. I do have the problem where the whole handle insert (if that makes sense) has cracked and kinda wobbles around. Will check the wires there and make sure there isnt any contact or grounding going on there. Gotta fix it anyways. Will let everybody know what the problem is... if I find it. If anybody thinks of anything else, please let me know.
Old 03-05-2008, 11:53 PM   #8
generationracing
generationracing's Avatar
generationracing is on a distinguished road
Default haha
try takeing the keys out ya pocket when you sit down
compare your life to mine and kill yourself
generationracing is offline   Reply With Quote
Old 03-05-2008, 11:59 PM   #9
ravenmaster
He has a stock alarm system which doesn't use a push button system it disarms when you unlock the door.
Also you might want to get a little more time on the forums before ribbing the older guys....
and by time i mean posts i know you have been here for 6 months or so
Old 03-07-2008, 12:47 AM   #10
generationracing
why dont you loosen up
1989 Supra alarm help... :( sizzor Non-Generation Specific Questions 8 11-07-2009 05:30 PM
Alarm Won't Deactivate (Please Help!) kauffmanstein MKIII Supra 4 02-14-2009 03:11 PM
alarm? starter? dunno help plz Scionguy MKIII Supra 3 11-04-2008 08:35 PM
the right way to disable your car alarm and still be able to drive. ogkush Car Audio and Alarms 0 02-06-2007 02:04 AM
Alarm MICAHMOBERLY Non-Generation Specific Questions 5 08-27-2006 10:00 PM
