-   -   Running Hot (http://www.toyota-supra.info/forums/mkiii-supra/10849-running-hot.html)
Benesesso 03-02-2008 01:22 AM
I've had this problem with both of my turbo Supras. I found a radiator shop that built me a couple of 3 row radiators. They helped, but the cars still run hot in the Phoenix summers. I changed the fan in the 1990 to a direct-drive stainless steel flex fan, and that helped, but it's a bit noisy.
In the summer, at ~110+ deg., both cars get up to ~220-230, on accurate gages, and the faster I drive the hotter they get. I run 50% antifreeze to keep the boiling point high. Both cars have good head gaskets.
I am convinced that Toyota screwed up and should have provided for a lot more airflow thru the rad.
sd88supra 03-02-2008 06:47 AM
^You should ask mrnickeleye about keeping your turbos cool. He lives in the desert as well and made some modifications to his N/A to keep it running cool, and they might help your turbos. Only I can't remember exactly what he did, but it had to do with cutting something out to increase the hot air flowing out.
mkiiisupra 03-02-2008 12:16 PM
The rubber seal that runs along the back of the engine bay above the firewall.... I know he removed that. it helps some heat escape through there.
Also make sure ur radiator cap is in good condition
supra_chick_1987 05-29-2008 10:28 PM
Head Gasket
Hey, my car finally spilled coolant everywhere when I drove it.....and I got the hydrocarbon test done. It was indeed the head gasket, though we are unsure of the severity of the problem.
My mechanic has said that this is a very costly repair, and he is urging me to get a whole new motor....what would you all recommend?
Please help me save my baby!!!!!:help::help:
Chambers 05-30-2008 11:27 AM
You could buy a new engine, but it wouldn't be smart to buy one and not do a rebuild, because that engine might have a bhg as well. Either way you are going to have to tear down a engine to see whats wrong if anything.
I would suggest you get the crank checked to see if it is withing tolerance of the TSRM, if it clears then you can do a rebuild on the engine you have now and keep your engine.
supramacist 05-30-2008 06:41 PM
Do an ac delete and get rid of the condensor blocking the radiator.
SC: Is this the same mechanic that unplugged your coolant sensor??
If it is. Find a new one or start gearing up to get dirty. Because if this guy didn't know about the sensor. You don't want him near the internals.
This is your car not a guinnea pig.
CyFi6 05-31-2008 01:31 AM
a new engine is going to be just as costly, if not more, and probably will blow a head gasket within a short time if its on the original gasket
Benesesso 05-31-2008 03:09 AM
>"Do an ac delete and get rid of the condensor blocking the radiator."<
Except that I live near Phoenix, and the days may not get below 100+ until October----.
dj7mge 06-01-2008 12:11 AM
rebuild what you have use a stronger gasket and try some water wetter it works really good for about 3months my dad uses it in his drag car dropped his operating temp from 220 to 180-200
JPJ 06-03-2008 03:21 PM
Exactly!!!
The fact that your mechanic did this leaves little room for doubting the fact that he is indeed a moron.
