Old 02-29-2008, 05:06 PM   #1
supra_chick_1987
supra_chick_1987 is on a distinguished road
Exclamation Running Hot
I have a 1987 automatic non turbo Supra...in pretty good condition. I've done a lot of work on it, but I'm stuck. Whenever i drive it hard (like on the freeway), then shut off the engine, I can hear it boiling. The temperature gauge says it's not overheated or even running hot, but you can hear it boiling. Upon recommendation by my mechanic, I've replaced the water pump, the thermostat, and the fan clutch. This seems to have corrected the problem of it overheating, but you can still hear it boiling. What should I do next? I've never run across this problem before!
supra_chick_1987 is offline   Reply With Quote
MKIV Supra TT Daytime Running Lights?? MIX MKIV Supra 2 08-30-2007 02:52 AM
Running Sooooooo Rich! Help! godgaveussid MKIII Supra 4 08-29-2007 08:46 PM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
