Old 03-02-2008, 06:37 AM   #1
sd88supra
Default A couple of questions
1.) How can I prevent high idle when starting the engine cold on a cold day? If its about less than 50?F outside and I start my 87 N/A the idle will be about 1600 RPM. I know its normal for it to be higher, but I think thats way too high, and its killing gas.
2.) As far as ignition timing, should I keep the stock 10? BTDC or should I go up to 15? I heard 10 is really only necessary to pass emissions here in California, and that an advancement to 15 will give a slight improvement in power and fuel efficiency. True? I checked the timing and noticed it was at 15 so I put it back to 10 to pass emissions. That was this week though, and I haven't had a chance to test drive on the highway to look for a power improvement.
3. What is the purpose of the sub oxygen sensor (California car)? I replaced my regular oxygen sensor almost a year ago but I didn't do anything to the sub sensor. Is it the same model as the regular oxygen sensor? I'm guessing I should probably replace it.
Thanks in advance.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 03-02-2008, 08:46 AM   #2
88Tsupra
try joining www.Socalsupras.com you might be able to get people to help you more. I had my timing at 15 degrees before and it makes for a faster in power band but it dies off near top end. So I'm back to 10 degree.
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 03-21-2008, 07:35 PM   #3
sd88supra
bump......
couple interior questions CyFi6 MKIII Supra 1 11-04-2007 08:42 PM
Fair price?, & a couple other questions WildBill Non-Generation Specific Questions 2 02-05-2006 11:30 PM
A couple questions G-string MKII Supra 4 02-01-2006 06:23 AM
Couple of questions Maverick MKIII Supra 5 01-13-2006 03:23 AM
