1.) How can I prevent high idle when starting the engine cold on a cold day? If its about less than 50?F outside and I start my 87 N/A the idle will be about 1600 RPM. I know its normal for it to be higher, but I think thats way too high, and its killing gas.
2.) As far as ignition timing, should I keep the stock 10? BTDC or should I go up to 15? I heard 10 is really only necessary to pass emissions here in California, and that an advancement to 15 will give a slight improvement in power and fuel efficiency. True? I checked the timing and noticed it was at 15 so I put it back to 10 to pass emissions. That was this week though, and I haven't had a chance to test drive on the highway to look for a power improvement. 3. What is the purpose of the sub oxygen sensor (California car)? I replaced my regular oxygen sensor almost a year ago but I didn't do anything to the sub sensor. Is it the same model as the regular oxygen sensor? I'm guessing I should probably replace it. Thanks in advance.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage. -1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car. -1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver. |
try joining www.Socalsupras.com you might be able to get people to help you more. I had my timing at 15 degrees before and it makes for a faster in power band but it dies off near top end. So I'm back to 10 degree.
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
bump......
couple interior questions | CyFi6 | MKIII Supra | 1 | 11-04-2007 08:42 PM |
Fair price?, & a couple other questions | WildBill | Non-Generation Specific Questions | 2 | 02-05-2006 11:30 PM |
A couple questions | G-string | MKII Supra | 4 | 02-01-2006 06:23 AM |
Couple of questions | Maverick | MKIII Supra | 5 | 01-13-2006 03:23 AM |
