Old 03-02-2008, 07:00 PM   #1
mkiiisupra
Default Innovative LC-1 work as wideband/narrowband?
heres how to wire an LC1 to work as a Wideband and a Narrowband at the same time - LS1TECH
Would it be possible to send a narrow band signal with this to the ecu? and then use the wideband signal and send that to my emanage?
Just wondering if i can avoid having 2 O2 sensors in my downpipe
1990 Toyota Supra Turbo A/T
Old 03-04-2008, 11:19 PM   #2
j3pz
i believe ive read a few wb o2 can send a signal as nb, but if i were you, id send an email to innovative and ask them. heres a link to the lc1.
LC-1 Lambda Cable with 02 Sensor : Wideband Controller Cable for Dyno, ECU, Data Acquisition, or Gauge Applications
Old 03-27-2008, 10:27 PM   #3
j3pz
did you ever email these guys? i dont know if you looked at the website i posted but it says the lc1 has 2 outputs so it may be possible to send one to the ecu and one to your emanage if it can send two different signals
Old 03-27-2008, 11:48 PM   #4
mkiiisupra
It does in fact have the ability to send a narrow band signal to your ecu.
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
