#1 |
heres how to wire an LC1 to work as a Wideband and a Narrowband at the same time - LS1TECH
Would it be possible to send a narrow band signal with this to the ecu? and then use the wideband signal and send that to my emanage? Just wondering if i can avoid having 2 O2 sensors in my downpipe
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
#2 |
i believe ive read a few wb o2 can send a signal as nb, but if i were you, id send an email to innovative and ask them. heres a link to the lc1.
LC-1 Lambda Cable with 02 Sensor : Wideband Controller Cable for Dyno, ECU, Data Acquisition, or Gauge Applications
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#3 |
did you ever email these guys? i dont know if you looked at the website i posted but it says the lc1 has 2 outputs so it may be possible to send one to the ecu and one to your emanage if it can send two different signals
#4 |
It does in fact have the ability to send a narrow band signal to your ecu.
Headlights only work on High Beam - is it a fuse? | t4yl0r10 | Non-Generation Specific Questions | 8 | 01-18-2008 03:56 PM |
N20 and HeAd WoRk | Supra_87_mk3 | Non-Generation Specific Questions | 4 | 05-25-2007 03:09 PM |
Dash lights Don't Work | supra67 | Non-Generation Specific Questions | 4 | 09-05-2006 04:58 AM |
Dash lights Don't Work!! | supra67 | MKIII Supra | 0 | 08-10-2006 01:11 AM |
