Old 02-16-2008, 11:04 PM   #1
marc
Default clutch pedal sticks
my car currently does not run, its an 88 turbo. when i push the clutch in as to start it, it does not return to the up position. the clutch pedal just sticks to the floor. how should i go about fixing this? low fluid? some sort of spring problem?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 02-17-2008, 05:36 AM   #2
rinso
rinso's Avatar
rinso is on a distinguished road
I believe that happens when the master and slave cylinders lose all pressure, which means air in the line, you're out of brake fluid, a broken hose or some goose has loosened the bleeder valve. When was the last time you checked your brake fluid level?
rinso is offline   Reply With Quote
Old 02-17-2008, 08:55 AM   #3
marc
brake fluid level is fine. but y wuld it be the brake fluid if its the clutch pedal not the brake pedal
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 02-17-2008, 09:33 PM   #4
Mark's MKII
Mark's MKII is on a distinguished road
He means clutch fluid level. Clutch master cylinder is near the brake master. It uses brake fluid also.
7MGTE
Mark's MKII is offline   Reply With Quote
Old 02-17-2008, 11:37 PM   #5
SilenceboneSupra
SilenceboneSupra is on a distinguished road
let someone bleed the clutchlines for you and see if it works back that should fix the problem if everything else is allright.
I had the same problem
SilenceboneSupra is offline   Reply With Quote
Old 02-21-2008, 01:26 AM   #6
ddmcse
ddmcse's Avatar
Cool
i'd bet your master cylinder is shot probably have a little stain down there on the carpet under the pedal too
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-12-2008, 05:44 AM   #7
88supra_dude
88supra_dude is on a distinguished road
same thing happened to me. took it to the shop and they said the master cylinder hose was bleeding. replaced it and now it's back up and running.
vroommm, vrooooommmmmmm -pshhhhhh-
88supra_dude is offline   Reply With Quote
Cluth Pedal sticks in freeplay range after releaseing the pedal??? fienloco Non-Generation Specific Questions 2 09-18-2008 09:43 PM
Clutch pedal sticks in range of freeplay??? fienloco MKIII Supra 0 09-09-2008 01:51 AM
clutch pedal sticking mk3000 MKIII Supra 2 06-12-2007 10:16 PM
clutch pedal to the floor suprabahamut Non-Generation Specific Questions 9 05-02-2007 12:35 AM
