Old 03-17-2008, 05:49 AM   #1
FunWheelDrive
FunWheelDrive is on a distinguished road
Default Supra Problem!!
When i start the car cold, it starts like a champ. Runs great, idles good, when cold idles at 1,200rpm when warm 700rpm. The only problem i'm having is after it's been running and i let it cool down then shut if off if i go to start it 15 minutes later it'll start then die, start then die, start than die, no matter what gas i give. Eventually i can keep it running by flooring the gas and it has a horrible misfire that clears up when i rev it high. I already change the spark plugs and wires. Runs really good otherwise.
Any help?
FunWheelDrive is offline   Reply With Quote
Old 03-17-2008, 07:04 AM   #2
CyFi6
I have issue with hot starts also, along with many others, although mine is not as bad as yours. From what i have read, the fuel in the rail gets so hot that it turns into vapor, and when you restart the car you are spraying out little liquid fuel.
My question is, is our fuel rail losing pressure when we turn the car off? There is supposed to be a good amount of pressure in the rail to keep fuel from boiling and doing this. Someone else needs to chime in.
Old 03-17-2008, 06:46 PM   #3
supramacist
supramacist's Avatar
Maybe it's time for you 2 hip cats to upgrade to walbro fuel pumps if you haven't already.
Old 03-17-2008, 08:42 PM   #4
FunWheelDrive
From what CY said it's not a fuel pressure problem when the car is running, its after the car turns off and has been sitting for 15-30 minutes.
Old 03-18-2008, 02:26 AM   #5
supramacist
If it was a design flaw it would happen to specific makes and models.
Kind of like the head gasket crap.
Something has to be losing pressure if this is an issue.
The 1st place I would look??? The injector grommets.
If they are hard and brittle. And they probably are.
They're under 10$ at the dealership.
Old 03-18-2008, 04:01 AM   #6
CyFi6
the injector o-rings dont contain pressurized fuel pressure.
Old 03-18-2008, 12:55 PM   #7
supradaddy0803
supradaddy0803's Avatar
Yes but the whole system is pressurized. If the grommets are brittle they will leak off the pressure and then you will have none when you try to start again. Hence the missfire. Check those and check your fuel pressure you will probaby be supprised at what you find. I think Supramacist had a post about this a long time ago or posted on someone elses thread. Granted it may not be that but if you replace them now then you will save yourself a problem with a gas leak. Which would you rather have.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 03-18-2008, 02:53 PM   #8
supramacist
It may not be the o rings for the injectors.
It's just a swell place to start looking.
Old 03-19-2008, 01:01 AM   #9
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Did you get any codes? Do you smell gas when you try to crank it when it's warm. Have you tested the fuel pressure? ECT sensor? I would check the ECT Sensor.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 03-19-2008, 05:29 AM   #10
FunWheelDrive
ECT sensor? Sorry i'm new to supras, i smell no gas at all. If i turn it off and turn it on five minutes later it runs alittle rough, wait ten minutes, gets rougher still twenty minutes it's 5 times cranking it over. But if i wait an hour it runs like it's completely fine. The only time i ever saw a code come on is when i went WOT and did a hard 1-2 shift and and the car like stalled for a second then went back to going to accel.
86 supra problem zumiez82 MKII Supra 2 06-06-2008 03:41 PM
*_*_*_*HavInG ProBLem WitH 87 SUprA (NO SPARK) d_demaree Non-Generation Specific Questions 5 05-22-2006 07:29 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
