#1 |
I'm in the process of taking out my transmission and it looks like all i need to do to make the tranny come out is take out the clutch release fork. How the hell go you get that thing out of there? The TSRM manual says, "remove fork" but it doesn't tell you how to release the fork. I see two fourteen mil bolts but there isn't enough room between the fork and the bolts to get a wrench or a socket in there. Any help would be great.
#2 |
you can also go by removing the E-clip that holds the pin through the fork. a bit hard and easy to loose but is quicker...good luck
#3 |
I have the r154 transmission, there are no clips on it. I have no idea what you guys are talking about when you say take off the clips. There are no clips! There are 2 12ml bolts. I got one loose the other is impossible to get off, there is 2mm's from where the bolt is to where the fork stand is. On the pivot point i see no clips nothing, just one end that has a weird shape, the other end is a round tube, i tried hammering on the tube lightly and again it didn't budge. How the hell do i get the fork off.
Thread Tools | |
Display Modes | |
trunk release cable? | dannydavi | MKIII Supra | 10 | 02-13-2008 09:38 AM |
87 supra hood release problem | EvilDragun | Non-Generation Specific Questions | 6 | 01-11-2008 01:38 AM |
Hood release cable | catawalks | Non-Generation Specific Questions | 11 | 04-24-2007 03:04 AM |
No release | west_side_supra | MKIII Supra | 16 | 11-20-2006 05:43 PM |
Quick release hub adapter!? | 88Supraboy | MKIII Supra | 4 | 03-04-2006 04:10 PM |
