Old 03-26-2008, 07:30 PM   #1
collink
collink is on a distinguished road
Default Boost and Stock Fuel
I want to know how much I can crank up the boost with my CT26 with stock fuel. This means: stock injectors, stock ECU, stock tune, stock MAF.
I'm really just looking for enough to throw my head back into the seat.
Thanks in advance.
- Collin
collink is offline   Reply With Quote
Old 03-26-2008, 09:50 PM   #2
mkiiisupra
you should search more before asking questions that have been gone over in depth multiple times....
10-12psi anymore than that and you will hit fuel cut.
But i would recommend reading alot more before you just turn up the boost....
1990 Toyota Supra Turbo A/T
Old 03-26-2008, 11:27 PM   #3
collink
Yeah, I know I need to do a head gasket and studs before I just crank up the boost. What else?
Old 03-26-2008, 11:28 PM   #4
mkiiisupra
The Search Button Is Your Friend.
Old 03-26-2008, 11:39 PM   #5
collink
I haven't had much luck...what terms do you recommend.
By the way, I PROMISE I searched before I posted this. I just don't think that my search terms were correct...
Old 03-26-2008, 11:43 PM   #6
mkiiisupra
http://www.toyota-supra.info/forums/...run-boost.html
http://www.toyota-supra.info/forums/...-websites.html
http://www.toyota-supra.info/forums/...iagnostic.html
http://www.toyota-supra.info/forums/...now-first.html
http://www.toyota-supra.info/forums/...-our-cars.html
http://www.toyota-supra.info/forums/...ock-tests.html
http://www.toyota-supra.info/forums/...mk3-supra.html
http://www.toyota-supra.info/forums/...ing-supra.html
That is all from one section, and does not require a search button. its the FAQ section if you have not found that its located here Supra FAQ - Toyota Supra Forums
Mkiv FAQ (Other Board) Critique/Discussion mrnickleye MKIV FAQ 7 03-03-2009 12:04 AM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
